since the last time I greased the chain, only in acceleration, the chain makes some bad noise, there on the sprocket.
if i pull the clutch , absolutely silence
I checked everything, tension (it's bit out of spec 52mm), alignment, rollers ... the only thing that leaves me a little perplexed is that the sprocket has no play. There must be a minimum axial free play, all my other bikes had it
So the questions are:
Have you heard weird noise came from the chain/sprocket in acceleration?
Have you got some sprocket free play ?
Richo
Top Posters For This Question
7
5
4
4
Popular Days
Oct 21
5
Jul 13
5
Jul 14
4
Jun 27
4
Richo 7 posts
NGarcia 5 posts
Combo 4 posts
Black99S 4 posts
Popular Days
Oct 21 2021
Jul 13 2020
Jul 14 2020
Jun 27 2022
Popular Posts
365moto.eu
I think you have to check here too: This little wheel turns really fast touching the chain... and sometimes its noise could be confused with that from the front sprocket.
thepointchris
I solved mine by installing rubber rollers with bearings, not bushings, end of problem. I struggled to explain it when I had the bike at the dealership, and could hear it mostly at steady speeds on th
itukusaes
This might help:
Posted Images
57 answers to this question
Register a new accountSign in
