Johnnyboxer
Front Fork Guard Nylon Lower Bolts
Johnnyboxer
Front Fork Guard Nylon Bolts - I found these Allen Cap Head Bolts on Ebay, they are M6 x 20mm.
To save breaking the lower fork casting in a fall with the oem Yamaha bolts, I just fitted these and they work a treat
All I added was a small 6mm washer, to give the bolt some 'purchase'
Cheap as chips, at 40p/bolt
Share this post
Link to post
Matth
Are they just number plate bolts?
Share this post
Link to post
Johnnyboxer
No
These are Allen cap head and match in with existing Yam oem fasteners
Number plate bolts may work though
Share this post
Link to post
XcTwo
Posted (edited)
Can you share a link to these?
Edited by XcTwo
Share this post
Link to post
Johnnyboxer
Just search ebay, M6 nylon bolts
I am in UK and got them here, sure to be some in USA too
Share this post
Link to post
boboneleg
I used these, they'll just snap off if there's a problem........
Brass Natural M3 273464865647. Hexagonal Screws. Knurled Slotted Screws. Nylon Black M3-M6 273887994760. Nylon White M3-M6 273888010732. Nylon Black M3-M6 273853377681. Nylon White M2-M6 273967823290.
Share this post
Link to post
BMRT7
Is this an actual problem people are having or just preventative?
Share this post
Link to post
TimmyTheHog
so far I believe it is preventive...unless I am proven wrong.
just that bolt is steel and the fork stanchion is aluminum, steel tends to win when a hard impact happens which is likely at the area.
Share this post
Link to post
Johnnyboxer
Reports of broken fork casting mounts in crashes
Share this post
Link to post
BMRT7
I was wondering. I know it’s apples and oranges but I have hundreds of hours on other bikes and have ripped fork guards off but never had an issue with the foot breaking.
link?
Share this post
Link to post
REDHORSECA
link?
No probs at all with my T7..... rides very smoothly and responsivly (albeit that's compared to my old Tenere 660) [ATTACH]
Quote
Copied from the UK fb- hope it’s ok
Feeling rather annoyed right now, took the bike down a fairly tame BOAT (hard packed dirt, bit of wet mud branches etc) and had a slip in some wet mud. No damage to fairings, handguards etc (all the stuff I'd expect to damage) but the bottom of the fork where the front fender attaches snapped off at the thread point.
The metal snapped with the thread still around it, seems like a bad weak point on the bike. Seen plenty of other bikes have the exact same type of fall and never break like this.
To top it of the front fender cracked in multiple places. Pics below for reference, Will get some of the bike tomorrow. Am I wrong in feeling the bike shouldn't break this easily given it's heavily offroad focus?
12193c7a-ea02-4e6c-a64a-dcd9fa4fa44e-jpe
  • Sad 1
Share this post
Link to post
jazzimus
Posted (edited)
Item pictured is actual item that will be received.
Nylon M6 screws to replace both the OEM steel screws on the outside of the lower front fender mountings.
These are designed to break if the fork leg comes into contact with rocks, etc on the trail, rather than the steel screws shearing off the lower fork lug (which has happened) and can then cause a costly repair.
White Nylon 6, 20mm long, with slotted head.
SUPPLIED AS A PAIR (2)
Edited by jazzimus
Share this post
Link to post
Tenere700.net is not affiliated with Yamaha Motor Co. and any opinions expressed on this website are solely those of ea individual author and do not represent Yamaha Motor Co. or Tenere700.net .
