Improving the feel of the rear brake
TimeMachine
MotoZ Tractionator.  I believe it's the Desert HT.
Thans for sharing. i too have a question: what rally pegs are those on the 700? They look perfect.
1 hour ago, johnnygolucky said:
Thanks for sharing. i too have a question: what rally pegs are those on the 700? They look perfect.
T7Rally.com pegs. They are lowered 35mm and back 15mm which gives my 36+ inseam some relief when sitting, and the transition to standing a lot easier. My only criticism is that they could be lighter at around 730 grams for the pair. Also fitting them can be tricky due to the heavy duty spring provided (but easy once you know how).
https://t7rally.com/shop/ols/products/lower-rally-foot-pegs-stainless
Ben from @T7Rally is a supporting vendor on this site.
Copy. I wondered. I have those exact pegs and the spring is a bugger but doable. My question  to you is how do you feel about the sifter now? And brake? I lowered the shifter as far as what is possible, and now with the lowered pegs I still have to lift my leg to shift both up and down which is a no go for standing riding off road. Im hoping someone design a lower and longer sifter lever as well as brake.
I lowered them as much as possible, and have got accustomed to it. If I had a choice I would lower the shifter a little more so would consider buying a different or adjustable shifter if someone developed one. The brake lever doesn't bother me, and quite like it a little proud compared to the peg.
Agreed.
  • 6 months later...
On 8/24/2020 at 1:05 AM, TimeMachine said:
Well I have talked about it long enough. The rear brake on the Tenere is a bit soft, lacking power and feel compared to the front which i rate very highly for a bike like the T7. In particular, it was the difference in feel and pressure required that had me frazzled. The front has a nice linear feel where the more pressure you put on the lever, the more power in the brakes. And it has plenty of power. The rear is not so good. I would press and press harder and still get only a little power. It was not until I stomped it would the rear braking power come on, and way too abruptly to control. I am a front braker anyway so with little power in the rear I tended to do most of the work in the front.
For ABS systems like fitted to the Yamaha, this actually works quite well. In the dirt, by not locking up the rear, the ABS system can accurately monitor the bikes speed and control the modulation of the front wheel. De-tuning of the rear brake may be a deliberate attempt by Yamaha to avoid issues with the ABS getting confused when both wheels lock up.
I always considered a change of rotor was the go because I had so much success with my MT09 when I changed all the rotors, and combined with the HH pads it's brakes are stellar. My MT09 uses standard calipers and rubber lines and can stop on a dime. There was only one way to really know if this would work for the T7, use the same rotor as on my MT09. I checked the size and was in luck, the MT09 uses the same rotor size and same mounting bolt pattern. So here goes...
Out if interest, which aftermarket disc did you actually use?
This one.
Racing Hooks. Handlebars & Clip ons. Oil Filter. Bling Kits. Moto Guzzi. ATV Radiator. Fork Air Bleeder Valves. Handerbar Riser.
nice find.  Worth a look.
How the he0ll are you getting 4ltrs per hundred.. I average 5.7ltr per hundred,  with my fuel gauge flashing at 200ks
Well you can take a look at how I ride (where I did the 4 L/100) here.
In general I dont use a lot of revs, lots of slower riding in the bush and dont usually travel faster than 100kph on the main roads to conserve my tires.
Fair enough.
Whats the accessory switch on the left side of the bar?
I see you have an ohlins shock, how's it and what's been done to the forks?
Wow awesome scenery! Im guessing you are a long way from help but what would you do if something happened like you got really stuck somewhere?
28 minutes ago, Mortaygo said:
Fair enough.
The switch is for an LED spot/wide light I have mounted under the lower triple clamp. It is not wired to the bikes high beam or electrics, just to the battery.
I really like the Ohlins shock. Very plush and easy to adjust compression, rebound and preload without tools.
The forks have progressive springs to suit my weight, Ohlins 5/10 weight fork oil with an extra 40ml in each leg, and some preload spacers to get the sag right. I have the compression and rebound turned up to 1 click back from maximum damping and the front is harsher than the rear on small bumps, but the firmer front doesn't bother me too much and handles the bigger bumps reasonably well. This was just my first test setting and haven't adjusted them since replacing the fork oil. Worth noting also that I run lower tire pressures (22-24 on the dirt roads) which takes a lot of harshness out of the ride.
Yeah, my riding has been quite remote lately and exploring rarely used tracks, but I have a Garmin Inreach on me so if I got into serious trouble I can text my son to come and collect me. The Inreach also has a feature that tracks where I am and shares it on a website, so if I was to fall unconscious he could look up the site and see where I was last recorded.
Thats a good system to use. Looks brill riding territory!
ride safe buddy
  • 5 months later...
3 hours ago, imteetering said:
Is the new brake rotor thicker than the stock one?
You got me there, so I measured them. The OEM disk and the replacement disk are both 5mm thickness.
4 hours ago, afhaldeman said:
For those interested, simply changing the pads makes a big and noticeable improvement as well
What pads did you use?
