Removing rear brake caliper
Tenerequebec
Hi
do i need to remove the rear wheel to remove the rear brake caliper because I need to reinstall the snall rubber part that retain this caliper!
  • 4 months later...
Save yourself the PITA dealing with the rear caliper when doing tire changes by holding it to the swing arm
with a quick tie.  Otherwise, you will need three hands to align everything during the re-install.  The picture
shows where the tie goes around the swing arm ...... it threads the caliper and keeps the caliper against the swing arm.
Edited by whisperquiet
  • Thanks 2
On a former bike I strugged with a similar set up with lots os swearing, poking and prodding. Your way appears to be eminatly sensible! Nice one
Great tip thanks, struggled like a bastard before putting new stainless steel bushs on 😤
