Wobbly GPS
Engineer
I cut one out of thin card first to make sure it would fit, and the bends would be in the right place.
Was thinking of doing something similar - I had two different devices on my bar and both tend to rotate themselves down when hitting bumps.
On my Super Tenere i had a similar problem and used a piece of gal;anized pipe strapping to keep my bar from rotating. It was pretty dumb but worked. Your idea here is much nicer!
You should upload a copy of your paper template so folks can copy it.
Mike
Its a brilliant job as said, wish you lived down here as building a half scale series one Land rover and there has been alot of head scratching!
