Complete Brake Line Kits - including ABS-delete options
Stoltec Moto
Another couple Stoltec Moto originals!  It feels like this project took longer than it should have - because it did.  Every time we were ready to button this up, we were presented with COVID supply chain ripples.  But I'm happy to report that after 2 months of prototyping, we're ready to roll these out!
We are now offering kits for sale:
  1. Stock Replacement - Eliminates rear hard lines to minimize leak points, reduce cost, and save weight (~1.7 lbs w/ optional aluminum banjo bolts).  Includes a +2" top line to accommodate taller risers or handlebars.  But yes, this works with the stock bars and risers, too!
  2. Rear ABS Delete - This is the really exciting part.  This kit bypasses the rear ABS circuit without introducing any warning lights.  Includes everything you'll need to slide the rear tire while maintaining ABS on the front wheel for the ultimate in safety and off-road performance.  Front +2" lines are included in this kit, as well!  Saves ~1.8 lbs w/ optional aluminum banjo bolts.  It's an amazing feeling to slide the rear tire down a rocky descent while keeping the front ABS engaged.  KTM upcharges for this software functionality, but Yamaha's lower-cost approach only gave us simple all-on or all-off option.  First world problems...
  3. Complete ABS Delete - For those who intend to ride predominantly offroad and want to bypass the front ABS circuit, too.  It wasn't long ago that all bikes came this way, but it warrants a reminder:  don't be stupid!
Here's a shot of what you're removing from the bike on the Rear-ABS delete...
For more details, see here:
Are you looking to tighten up the brake feel on your Ténéré 700? Stoltec Moto teamed up with Spiegler to develop these kits, and they help bring the performance of the brakes in line with an otherwise stellar chassis and engine...
stoltecmoto.com | 610.252.7232
The Stoltec Moto Build Thread
I did this bypass myself. But I had problems that when I locked the rear wheel at a higher speed. Seems like the ABS system felt something was wrong and turned off the system and turned on the ABS lamp.
Sorry, seems like forum updates aren't making it to our inbox.  Are you using our kit?
  • Stoltec Moto changed the title to Complete Brake Line Kits - including ABS-delete options
Due to a few customer requests...we developed a complete ABS-delete option.  Ready to order now, this kit goes old school - the ABS pump is bypassed completely.
Have you tried to duplicate this result with your kit?
I am assuming your kit physically bypasses the ABS pump and plugs the connections.
J
We have three kits now:
The rear ABS delete kit removes the connection between the ABS pump and the rear brake circuit completely.
The ABS delete kit removes the connection between the ABS pump and both brake circuits.
The stock replacement kit leaves the ABS connections to maintain the factory configuration.
With any of these kits, DO NOT remove any of the electronic devices or electrical harnesses. This includes the wheel speed sensors.
