SuperMoto T7?
Rich TT
It's a fairly tricky modification.
On the front wheel,
1.you need to remove down 5 mm .the width of the front hubs on both left and right sides.
2. and expand ้hole  the bearing slots, both left and right (use the original bearings and the original shaft of the t700 at all)
3. Build a shaft sleeve in the middle of the wheel to fit the bearing on both left and right shoulders.
***brake disc  mounting nut    you can use standard  t7
4. Wheel Collars - Spacers  L/ R side  you can make new side or use standard cut out  i forget ....dimension
on the rear wheel , easy
1. Build adapter, aluminum, thickness 10 mm. with drill holes, fixing abs plate.
2. you need Longer brake disc mounting nut + 10-15mm.
3.Wheel Collars - Spacers  need new  R side
4. L side  rear sprocket /Wheel Collars   hub use the original
