A few more additions
Rich TT
41 minutes ago, cabby said:
Guessing you fitted an led relay for those indicators, how does one go about fitting said relay ??
I didn't actually fit them. They're the genuine flasher plus ones from Yamaha and I think the relay/resistor is within the indicator itself.
Cheers
11 minutes ago, Symon said:
The can you have,is it the carbon oval?...any video of sound?..thanks
Yes carbon oval. I have a video of the sound but too large to out on here. I'll try and just record the sound at the weekend if that works.
How much weight saving is there to be had with this end can.
Im also waiting for a post with the sound without baffle.
Aleks
Aleks
Kg's lighter. The standard pipe weighs a ton. If you search for MTC exhaust for the Tenere 700 you'll see plenty of sound clips. I'm not sure I can post a sound clip on here as I think it only allows pictures.
Cheers
The relay resistors are built in so no need.
Rich
