DonaNobisPacem's T7
DonaNobisPacem
Entry Date: December 22, 2022
Changes Made:
  - Installed CamelAdv Minimalist Rack
Installation was fairly easy. It was a bit sketchy whether or not it would work with my existing grab bars, but fortunately the bolts that came with the grab bar were just barely long enough. I've already placed an order for longer bolts though since the grab bars are a load-bearing part when I move around the bike and I am in no way comfortable doing that with the current length of the rear bolts.
IMG_20221222_205811.jpg.4b2fefd29a216e17bac2c12817c98634.jpg  IMG_20221222_205823.jpg.fa65470b82fecf90001a50a225c8b1dd.jpg
  • 5 months later...
Entry Date: January ??, 2023
Changes Made:
  - Installed CamelAdv "The Fix" rear brake lever
Edited by DonaNobisPacem
Entry Date: June 1, 2023
Changes Made:
  - Changed oil using Motul 7100 10w-40 at 5000km
  - Changed oil filter using Hiflofiltro HF204 at 5000km
  - Replaced stock drain plug with magnetic drain plug (https://www.amazon.com/dp/B09MWKSGL3?psc=1&ref=ppx_yo2ov_dt_b_product_details)
  - Replaced throttle tube with the R6 throttle tube (https://www.amazon.com/dp/B005C59NO2?psc=1&ref=ppx_yo2ov_dt_b_product_details)
  - Replaced stock grips + grip puppies with Progrip 714s (https://www.amazon.com/dp/B000WO8MKY?psc=1&ref=ppx_yo2ov_dt_b_product_details)
  - Added exhaust pipe guards since my boot rubbed a hole through my exhaust wrap
IMG_20230601_192402.jpg.7dde4ca8230b88f43959052f74e25878.jpgIMG_20230601_192434.jpg.d0b3adfbadda9a97f52822bf21a4e10f.jpg
Entry Date: September 15, 2023
Changes Made:
- Flushed front and rear brake fluid and refilled with Maxima Dot 4 brake fluid.
- Uninstalled stock side mirrors
- Uninstalled Zeta handguards and shield turn signals
- Installed HDB handguards, side mirrors, shield turn signals, and anti-vibration insert
HDB Kit:
Anti-vibration insert:
HDB handlebar clamp:
Bent the brake line over the clamp to make it fit. A bit tight, but nothing is being strained too much as far as I could tell when testing it full handlebar lock on both sides.
Cut off the what I believe to be KTM connectors that come with the turn signals and replaced them with generic bullet connectors:
All put together feat. unfinished handguard protector made out of 550 paracord:
Almost as bright as my Cyclops Aurora halos. Wish I could say the same for the TST flush mount turn signals.
Entry Date: November 9, 2023
Changes Made:
- Repaired cracks in Camel Adv Tail Tidy
Before:
20231105_144004.jpg.d5e716b74e82275ff50ac810239a0ffd.jpg20231105_144014.jpg.17f7dd33be9066072b9c9efef2a58d70.jpg
20231107_093215.jpg.094a293c47dab931b8d695219082036b.jpg20231107_093355.jpg.b9bf696e4986cc715ce06740455df4cf.jpg
After:
20231109_124920.jpg.0005b4fa4aee1f44dfdcfc8ea5617804.jpg20231109_124926.jpg.befc14fe9f4c8f1a2853797d49eb9fdc.jpg
