MotoWinch 2500 - Tool Tubes
DuncMan
 Share
I have the Burmot rear rack and soft luggage plate. Was trying to figure out how to hold tools plus the MotoWinch 2500. This is my solution. Two tool tubes, one containing the main elements of the winch, the other just the hand winch part plus some other tools. This tube installed nicely under the right side of the Burmot soft luggage plate. I have another arriving tomorrow for the right side which can either contain more tools plus the hand crank or a 1.5L bottle of fuel.
OverlandRider.com
And the final product:
OverlandRider.com
Not sure if that will hold.
When the tywrap breaks the mounting point on the tooltube will also break.
It might be at bit less as when you mount it on its side like i had on de Crosstourer but that one went flying on the TET south Netherlands.
Made a new mount and on the XT660Z i also cut the mounting points off and used 2 exhaust mounts.
This is what happened and what i made for the CT.
IMG_20200511_161200.thumb.jpg.dbb5f792f8d8fbaff183d6006b1d123b.jpgIMG_20200511_182329.thumb.jpg.ceac2cbb3a034c7f7fcaaefa7968feef.jpgIMG_20200511_182430.thumb.jpg.be644362f716707bda43a656d3429ac3.jpg
IMG_20200511_184701.thumb.jpg.1837fa4fb4dacf8307c5eecc0b882f77.jpgIMG_20200513_064746.thumb.jpg.5503476bbebdb7485384d37e0d454b50.jpg
And this is what i did with the XT. Went for a single exhaust and used the second exhaust mounting point plus a home made mounting point.
Ray, you're spot on. My original idea when buying these was to manufacture brackets exactly like you did. If I'd been doing a TET that would have been the only way I'd have gone. However, I won't be doing TET's and mostly just touring and light off-roading and I believe these will hold fine for that. And if they don't, I'll make some aluminium brackets for them. 👍 Your brackets look the business, tho.
OverlandRider.com
You don’t find the twin torpedo tubes obscuring the tail light excessively? May just be the perspective in the pics, but it appears rather disappeared.
I was wondering the same.  Ticket waiting to happen?
A ticket at best, rear ended at worst.
@DuncMan Here, fixed it for ya!
  • Haha 5
"Men do not quit playing because they grow old, they grow old because they quit playing" Oliver Wendell Holmes
No, it’s just the pic. Tail light shows just fine.
OverlandRider.com
Rear light with double tubes.
OverlandRider.com
Mate, just to update this thread. Initially it looked fine but I studied this mount further and whilst the tail light is perfectly visible from directly behind, it's obscured from either side. For that reason I'm removed them and back to the drawing board.
OverlandRider.com
Fair play Dunc. Kinda my thought,
that it was highly obscured from anywhere but 6 o’clock.
  Takes an admirable dose of smarts & humility to actively second guess ourselves. Good luck back @ the drawing board!
Cheers mate. Yeah, didn't want others to purchase the tubes and try the same thing only to find out they didn't quite work. I regularly eat humble pie so I'm getting used to the taste now.. 😁 Still, if we don't try new things we don't learn and this wasn't an overly costly mistake, at least. The solution has been found tho. The Bumot tool box has arrived today and will be fitted to the pannier racks it's designed for. That will nicely carry the bits I wanted to transport in the tubes.
Edited by DuncMan
OverlandRider.com
Cheers @DuncMan. Humble pie is definitely an acquired taste, many don’t like it much. I’ve learned to appreciate it in my travels. We can learn & share a lot more that way.
Yeah, I'm now old enough and long enough in the tooth to park the ego and admit when I didn't quite get it right. Today I installed the Bumot tool box and that's worked perfectly. Very tidy solution. It has a nice lock, too so for now I've locked my ego in that. 😁
OverlandRider.com
 Share
