Stripped bolt at base of rear shock
mrboni
32 minutes ago, witgen said:
For some reason japanese engineers seem to be keen on these kind of bolts.
Then they can sell you a new bolt every time you undo them.
These stretch bolts are one time use only but i rarely teplace them.
Depends on the state of the bolt and the location.
I doubt that Yamaha is putting crappy bolts on their bikes.
My suspicion is people are getting oil/grease on the bolt, nut, or mounting surface.
Torque values need to be cut in half if you do.
Oh, very good to know!    It's likely mine was greasy after a liberal application on the linkage bits
Mr. Boni,
I learned this lesson (The Hard Way) and never forgot.
If you google the subject you will see oil, grease, anti-seize, even loctite will affect the torque values.
Lubing the linkage and fasteners is not a bad thing, corrosion is always a worry.
Using a torque wrench shows that you care and try your best to do the right things, I commend you!
It is just that sometime we need to read "between the lines"... if you know what I am saying.
Best of luck to you my friend...
Bob
I do.  Much appreciated, and much to learn 😆
It was a little crude but I started with nut splitter, which split the nut but didn't get through the flange / collar bit.  However I was able to grab it with mole grips in this state and unthread it
Oops I accidentally deleted my post. Thanks so much for the quick reply.
Glad to hear the nut splitter did the job, luckily I was able to remove the upper dogbone bolt and use the dogbone itself as leverage to pull back on the nut while unwinding - it managed to come off in the end without needing to cut anything. (Phew)
On 5/12/2022 at 2:36 PM, Hibobb said:
Mr. Boni,
Bob
Actually I wonder if this was also my case here - as everyone was making a big deal of greasing the linkage bolts, I wonder if I got grease on the threads when pushing it through. Next time I will thoroughly clean the threads as best I can before putting the bolt on.
Don't forget the swingarm bolt. When that one gets corroded and locked in place it is a nightmare to get out.
T7 is currently too new for that to have happen yet... Old times have heard lots of stories about unmovable swingarm bolts.
