AS side rack with Unit Garage rack?
XT-Michi
Hi all,
I am new to the forum and recently bought a T700 rally (2021), after I had a XT660Z for 5 years.
T700 preowner has installed a rear rack from Unit Garage (Italy).
I was thinking of adding side racks from Adventure Spec, as I am using soft luggage from Touratech ("Touratech Extreme edition", similar to Enduristan Blizzard XL, but a bit larger). Has anyone experience with this combination of side/rear racks ? Not sure if they will fit together...
Thanks in advance. Greetings from Germany, Michael
The AS side racks fit with the AS top rack, which uses the same attachment points as the rack you have, so it's quite likely that they will be compatible. If not, the AS top rack is reasonably priced as a replacement for your existing rack.
