Any recommendations for a lowered centre stand
EstRider
Hey gang,
 Finally lowered the my world raid 25mm  and put the camel short side stand on it.
 Taking the OEM centre stand off as with the lower height I can no longer get the bike on it without herculean effort. Anyone have any suggestions for a lower centre stand?
 Some quick Google foo has turned up little.
Hi mate, I've got a 2022 World Raid and took a chance on buying a 2020 Tenere main stand cheap off eBay. Fits the bike no problems but when the Raid is put on the main stand the rear wheel just touches the floor - I turned up a couple of  10mm"hockey pucks" to add extra height if I need to get the rear wheel off the floor.
I would think with your bike being 25mm lower the 2020 stand would be a good fit, the bike is easy to get on and off the stand as well.
Hope this helps.
Good idea. I've got a used H&B centerstand (standard model, not for the WR) which I don't need any more, because I raised my suspension by 25mm. It's now too short, the wheel still touches the ground a bit. Might be a good fit for a lowered WR.
Thanks guys, I clearly lack a poor understanding of physics. Sorry about the late reply! I've found if I remove the side panier I can muscle it up onto the centre using the luggage rack, it's definately harder then before and if I don't lift from that far back 0 chance of putting it on the stand. So manageable for now, but that sounds like a great solution as well! Thanks for the replies I appreciate it!
In the longterm my solution will be more Gym!
