Yamaha Tenere 700 Fuses-Amp specs
Cruizin
Backup fuse? Same as spare?
  • 6 months later...
On 2/22/2020 at 11:39 AM, H700 said:
The "bible" says...
The owner's manual excerpt specifies the auxiliary fuse at 2A, but does specify the accessory fuse.  From the first post, it seems to be 10A.  What is the source for the first post?  Shop manual?
Which fuse is for the car cigarette lighter, accessory or auxilary? I bought a tire pump, but it blows the 2A fuse on my scooter (still haven't received my T7) The maker doesn't respond to my enquiries about the amp rating on the pump.
Edited by Jellebo
@Jellebo You might have to utilize the trial and error method. Plug a 2A or less device into the T7 cigarette lighter socket, then pull fuse # 4 then #5 ( in the schematic 2 posts above) and see which fuse feeds it.
Here's a good thread to read regarding accessory plugs.
On 2/22/2020 at 10:39 AM, H700 said:
The "bible" says...
I have the pdf manual.  Is this page from that?
#5 2A 🙂
