T700
Tuning the Cp2 engine
Aleksandar13
6 minutes ago, pgeldz said:
Yes,
I'll break it down for you:
Rapid Bike EVO - real time auto adaptive fuel controller, transferable to other bikes, just need to buy bike specific harness and get the unit reprogrammed for the new bike by a Rapid Bike dealer.  Has add on modules you can add later if you wish, like quick shifter, Blue Bike, You Tune, etc.
Rapid Bike  Exclusive - same as EVO, but locked to only have the programming for the bike it's for.
Rapid Bike RACE - same features as EVO, but adds a static timing map for the bike it's programmed for (and it makes a difference, I've had both on my Yamaha R3 racebike).  You can also go into the software and change the timing if you wish, for race gas, etc.  Has the same add on modules as the EVO, but more functionality is available in the RACE then the EVO for certain things.
I'd hold off on getting it though.  I work for a place that will most likely be a Vendor on this forum, and we will be offering group buys on several products for the Tenere 700.  I have one of these bikes on order personally in the USA, and can't wait to get my hands on it.  I also race a Yamaha FZ-07, and there are some parts that cross over since it uses the same exact engine.
So again, I'd hold off, because you may get a better deal when we become a forum vendor.
And just so everyone knows, I'm not here to solicit.  I don't make commission on the products sold at my workplace, so I have no angle here.  I'm getting a Tenere 700 for myself so I'm just as much of an enthusiast as everyone else on this Forum.  When I DO post stuff that leads to a link of some new product, etc, it's really just to make people AWARE that these products exist, as many may have never heard of them before, since the shop I work at caters to Italian manufacturers.
- Paul
Great thank you for your explanation... Before I am ready to pull the trigger I will check here first.
Don't think for me personally I would need it to be transferable to another bike so the exclusive might do the trick.
This mated to the exhaust and a Mwr filter with the plate for the airbox should make the bike song up to the top.
Let us know how what products are in the pipeline.
Aleks
Share this post
Link to post
pgeldz
Aleks
Will do.  In the process of becoming a forum vendor as I type this...
- Paul
Share this post
Link to post
Bad Pritt
With a group buy of the Rapid Bike  Exclusive i'm interested!!!
Share this post
Link to post
pgeldz
It's happening!
I'm working out the details now...
Check the BellissiMoto section in the Vendor area soon!
- Paul
Share this post
Link to post
DWEL700
How will these effect warranty?
Share this post
Link to post
pgeldz
Warranty claims are handled differently different countries, but since Yamaha themselves have a foam filter I wouldn't think it would matter much.  The filter is easy to access, so if you need to have service work done, it's easy enough to remove and install the OEM components 🙂
- Paul
Share this post
Link to post
pgeldz
If you were talking about Rapid Bike, please PM BellissiMoto.
Share this post
Link to post
DWEL700
Sorry I meant the tuner not the air filter.
Share this post
Link to post
Aleksandar13
On 4/30/2020 at 5:42 PM, pgeldz said:
It's happening!
- Paul
Paul thank you for all the input... I think what most of us are keen to see is some dyno charts from mt07 forums.
I personally would like to see a before and after of filters as well as a before after with tuning module.
If you could post something this would really be helpful to us all.
Appreciate it.
Aleks
Share this post
Link to post
pgeldz
Appreciate it.
Aleks
All the before/after charts of the filters can be found here:
fz07_sharer_logo.png.3fd3e4f66c84e31060f
Hi everyone... So, its finally time to do my 8K service, and I thought Id change my DNA air filter to a new one. Im pretty particular, so I never just clean, re-oil, and reuse these reusable filters...I just buy a new one. I figured instead of ordering a new DNA filter from Greece (there are no U...
All the charts I have after I removed the Power Commander and installed Rapid Bike were with my built motor for MotoAmerica, so it would be of no use unfortunately.
Share this post
Link to post
Bad Pritt
Does any1 know if it's possible to get the fan starting at a lower temperature with the RB module?
Share this post
Link to post
2 Wheel DynoWorks
The cooling fan engagement temperature is lowered to ~200 degrees Fahrenheit with our ECU flash!
-2WDW
Share this post
Link to post
pgeldz
Posted (edited)
The fan temp control is within the ECU.  However, I race my FZ-07 (same CP2 motor) with a full Rapid Bike set up in 110 degree heat and it doesn't run hot, so I don't think it's absolutely necessary.
I've seen too many tuners at the track use over aggressive timing and/or improper fueling (lean condition) to make power, at the expense of more heat into the engine, then use the fan temp to try and control it within the ECU.
If the fueling and timing is right to begin with, which Rapid Bike does exceptionally well, you shouldn't run hot.
- Paul
Edited by pgeldz
Share this post
Link to post
We are just Tenere 700 owners and fans
Tenere700.net is not affiliated with Yamaha Motor Co. and any opinions expressed on this website are solely those of ea individual author and do not represent Yamaha Motor Co. or Tenere700.net .
