Posted May 8, 20241 yr Hey, Im thinking of buying the world raid Because of the better suspesions But I dont need the 2 hole tank fuel I thought of changing to the acerbis one For less whiegt Buying the regular and upgrading the suspensions will be alot more expensive Someone did it already ? Or maybe knows if its fit?
May 8, 20241 yr The design of the one tank and two tanks are totally different. Anything can be done but it would be a big project. If you are after the suspension then the Extreme version has the same suspenstion with the single tank. If you are located in a market that has the world raid then you should be able to get the Extreme model. Edited May 8, 20241 yr by Toymaster 2006 R1, 2018 XR650L, 2022 T7, 2023 Desert X, 2024 WR450F, 2024 YZ250X, 2025 V2 final edition
May 8, 20241 yr Here is the first video showing the differenet models I found. Found this one also... Edited May 9, 20241 yr by Toymaster 2006 R1, 2018 XR650L, 2022 T7, 2023 Desert X, 2024 WR450F, 2024 YZ250X, 2025 V2 final edition
