Posted May 21, 20241 yr Hi folks, Seems the previous owner put a bung in the cat(I'm assuming it's the stock header) where the O2 sensor would have been. I know he had an Akro can on it at one point but it's got the stock can at the moment. My question is: should I be trying to remove the bung(it looks pretty rusted in there) and put the sensor back? Thanks!
May 21, 20241 yr It depends. Do you know if the bike has been mapped? Some remaps require the sensor disconnected to perform at its best.
May 21, 20241 yr At the very least, take the bung out and use some anti-seize on it. The next guy will thank you. We are all tattooed in our cradles with the beliefs of our tribe ~Oliver Wendell Holmes~
May 21, 20241 yr Author 2 hours ago, Alan M said: It depends. Do you know if the bike has been mapped? Some remaps require the sensor disconnected to perform at its best. Not absolutely 100% sure but pretty confident that it hasn't been mapped. Any compelling reason to try to get the bung out and reconnect the sensor?
May 22, 20241 yr If it hasn't been remapped or otherwise messed with, it should throw a light with no O2 sensor I believe. Tusk crash bars/pannier & top racks/hardcases/footpad/Olympus tank bag, Camel ADV One-finger clutch kit, Rox risers, fleabay tail tidy, Delkevic full exhaust w/ 14" carbon oval can
May 22, 20241 yr Community Expert Members 6 hours ago, cgrahams said: Not absolutely 100% sure but pretty confident that it hasn't been mapped. Any compelling reason to try to get the bung out and reconnect the sensor? If it's running fine, keep it that way. I agree with @406T7, there should be an engine light active when this sensor is missing. If this isn't the case, it might well be yours is remapped already.
May 22, 20241 yr Would it throw a light if it was still connected? Not sure myself, mine was disconnected after remap but sensor left in the pipe. Might be worth checking you actually have a sensor still connected.
May 22, 20241 yr I have a remapped ECU and dominator decat downpipes. The O2 sensor is unplugged at the exhaust but still present on the wiring loom. There was only one fault code produced and that was when the ECU was reinstalled. This was easily cleared with a cheap ODBC reader. The disconnected O2 sensor does not give me any fault codes after three years of use.
May 22, 20241 yr Author 8 hours ago, 406T7 said: If it hasn't been remapped or otherwise messed with, it should throw a light with no O2 sensor I believe. Hmm, interesting
May 22, 20241 yr Author 7 hours ago, Tenerider said: If it's running fine, keep it that way. I agree with @406T7, there should be an engine light active when this sensor is missing. If this isn't the case, it might well be yours is remapped already. Thanks! I'll see if I can find out if it's been mapped(bit of a language barrier with original owner) but yeah it's running fine. Was wondering though if he mapped it for his Akro and now it's back to stock would it adversely affect performance? It's running fine but I have no frame of reference as it's the only T7 I've driven. Edited May 22, 20241 yr by cgrahams
May 22, 20241 yr Author 4 hours ago, Alan M said: Would it throw a light if it was still connected? Not sure myself, mine was disconnected after remap but sensor left in the pipe. Might be worth checking you actually have a sensor still connected. I'll do some more poking around-thanks!
May 22, 20241 yr Author 4 hours ago, Tommac said: I have a remapped ECU and dominator decat downpipes. The O2 sensor is unplugged at the exhaust but still present on the wiring loom. There was only one fault code produced and that was when the ECU was reinstalled. This was easily cleared with a cheap ODBC reader. The disconnected O2 sensor does not give me any fault codes after three years of use. Thanks! I am looking for a high mount exhaust solution and was thinking about the dominator.
