Bits removed
razz007
As with my previous tenere , I moved all the electrics to under the seat and left the panels off . But never really got there , so after collecting this one today from its first service , I moved the electrics , and left the panels removed plus rear seat . Have ordered another rear mudguard to cut up to help with water etc . Love the beginning of my mad max tenere 700 fireblade .
Would love to see details of to our relocation efforts. Been meaning to move my ECU over since my luggage rack is punching a hole in the plastics right around where it is.
advgoats.com
Basically I cut the cable ty’s , removed the airbox bolt , moved all cables up , ecu unplugged and plug pushed thru to under seat , bolt replaced and ecu plugged back in , cable not tight , ecu lays flat under seat , seat holds it nicely
@razz007 Do you have a photo of under the seat from the top?  That sounds like a good way to keep the electronics out of harms way.
