Rally Raid 80n/mm Spring
Hawkerjet
I tried going with this stiffer spring for my weight 185 lbs, just me without gear. This spring selection was confirmed by Rally Raid and Race Tech as the proper spring for my weight without luggage. All I ride with is a small tail bag, less than  5 pounds.
While it did improve the handling it was a bit too harsh on rough roads for my old, delicate, worn out back so I went back to the stock spring.
The spring only has 150 miles on it so you could call it new. I got it from Rocky Mountain ATV for $145.88 plus tax.
You can be an owner for $75 shipped.
Oh by the way regarding proper rear sag: 1/3 of the suspension travel would be right at 66mm. I have seen posted on this forum 60mm for loaded sag. Certainly that will work. It will give you a bit taller in the stroke ride height and also a noticeable harsher ride.
