I have just recently purchased a 2024 T7, which I love.  I am just after some advice on adding a  lightbar.  I am looking to mount it to the lower fork clamp using the existing M6 threaded holes.  Has anyone  added a lightbar to their T7 in this position?  And if so, do you have some advise around Yamaha's sensitive electrical system?  And if so do you has a diagram and measurements for the bracket that you used or does someone make these?  Any help or advice would be greatly appreciated.
I used the Kedo kit - It was plug and play on my T7:
Application: Ténéré700 (XTZ690) 2019 and later (cannot be combined with towing eye item 31052 or mudguard item 31092)  LED Light Bar LED auxiliary high beam that is also steered! Best illumination thanks to...
They also sell just the bracket if you want to source your own lights for it. I added a switch so I can tur it off if needed.
The Kedo kit is interesting, but they don't ship to the U.S.  Is there a Kedo distributor who does?
Looks like they have a distributor in the US:
USA
Distributor:
The Vintage Spoke
TT & XT Parts Specialist
thevintagespoke.com
+01 785 577 70 55
Tenere is not their specialty,  I'd call and talk to them. They do have the full catalog and what you want is on page 591.
Rigid makes a nice one as well. Have it on my Super T, and have one for my T7 that I will be fitting later this year after riding season is over.
The SR-Series PRO LED Light Bars provide a sleek, low profile lighting solution that measures less than 2” tall. Thanks to improved LED technology, the SR-Series PRO now offers more light output than ever before with up to...
I also use the Stedi 6" light bar, cheap and good light.
I use the ADV ENG mounts (Australian Made):
Tenere 700 LED light bar mounts are in and being preped for shipping. I'll post more details up this afternoon. Cheers. F.
And I used the Skene LQ -2075X controller.  This will gaurantee you will not kill your ECU:
Skene LED Dimmer by Cyclops Adventure Sports USA. The IQ-275 Intelligent Lighting Controller from Skene Design allows you to quickly and conveniently set the brightness of your auxiliary lights to match riding...
  Yes, it's expensive but it's cheaper than a new ECU and it gives you the ability to use the light as a running light.
Edited by dnrobertson
