Barkbusters & Asv Levers
Stephen H
I did put the issues I had with this combination in a thread before and my intention was to refit the standard levers with the Barkbusters but thought I would try sort it out some way. I purchased some bushings which are 13mm long and has cured the problem of the Asv lever body hitting the Aluminium stay of the Barkbuster. I would say a 15mm bush may have been slightly better but as you can see in the pictures there is clearance. The bushing were purchased from eBay.
Another thing I will be replacing those bolts for dome heads when I get the chance.
