engine cuts out
bth2
hi,
i went for a spin yesterday and when coming down a steep switchback lane ,about 1 in 5 (20%) the engine cut out. stopped,restarted ok. has anybody had this issue?
44 minutes ago, bth2 said:
hi,
How was your fuel level?
Check the manual,, it mentions a lean angle engine cut off sensor IIRC. Its on the bike in case of a tip over, perhaps the lean/hill just triggered that
Another item to add to my "lets find what useless shet I can remove" list.
3 hours ago, Louis said:
Side stand switch?
i have sidestand switch delete so not that
from full i had used about a gallon...so unlikely
i had thought of that but does it work at all angles or just when on its side?
My understanding is that lean sensor cuts out the engine if bike is on its side because oil pump may not be able to pick up oil in the sump. Incline of hill wouldn't initiate that sensor.
Loose electrical connection or bad ground? Bad fuel?
Locked rear brake while in gear with clutch out?
2021 Yamaha Tenere 700
2019 Husqvarna TE 250i
2018 Husqy/Oberon/JD FE 450
Side stand delete plug?
Assuming the ABS was on that couldn't happen.
Actually the ABS does not operate below 10kph, so if the vehicle was below that speed with the drive line engaged it could be possible. But I suspect at that speed you would notice if the rear wheel was skidding and you hadn't been quick on the clutch pull.
Also if the engine cuts out due to the lean angle sensor, the check engine light comes on and you have to turn the ignition off and on again. If you didn't do that then it's not the lean angle that made it stall. I'd still doubt it was the lean angle sensor. My bike runs for several seconds when it's on its side before the engine cuts out.
The bike also stops if the engine idles for 20 minutes, but I'm going to assume you didn't ride for 20 minutes down hill in neutral or with the clutch in.
Assuming you pulled in the clutch and then the bike stalled, my question would be, how fast was the engine going when you pulled in the clutch? I say because 99 percent of engine stalls are caused by the rider 😉 When rolling down a hill it's easy to forget what gear your in and end up slowing right down while in 5th or 6th and dragging the engine below idle.
Edited by Hogan
update
Nope I have never had this happen.
All of the above are valid....
Did you go back up and retry the hill decent.
Is your side/kick-stand delete done well. Think it was a one off.
No engine light on means that it was not the (left to right) lean angle sensor
@Cruizin no no no no please don’t have a go at removing the lean angle sensor: it can save your engine from no oil pick up when the bike is on it’s side. It also helps prevent and limits fires and fire damage as the fuel pump is cut off in a crash / slide off. And in a fall off / over you don’t want the back wheel still turning round as the bike can circle around on some ground, especially with knobbly tyres on. Also the wheel, chain and tyre can all drag a foot / leg in etc if your leg / foot is trapped below on left side falls. All that is needed is to lift the bike back up again and then switch the ignition off and back on again to reset it all, it is a grand and very very good safety system.
Think this thread title may be a little bit better, may be edit to ‘Engine Cut Out, on step decent’ as “Cuts out“ implies that it has happened a lot, and this sounded like a lone one off to me. Cut and Cuts is different is all I am saying and I don’t think it is a common cut out thing.
Yeah fuel level etc, high gear low speed chug out, ABS off etc. I would have repeated the hill decent, to analysis it and see if it would happen again and spot it out.
It fired up again, hope all is good.
Happy days.
Another cause of problems are modifications. Stock exhaust? Stock intake? Quick turn throttles? Modifying anything can cause problems.
Modified intakes and exhausts, and blipping the throttle at idle can cause flameouts. If you were close to idle and went to rev the engine to change down gears then a stall could happen.
Sorry to revive an old thread but I did have one mystery stall while coasting with the clutch in. Took it to the dealer and they pulled an event code, but the event code had no details. It was a hot day with about a half gallon down from full. The only thing we could think of was my tank bag was on too tight causing a venting issue
just a note to say this has never happened again....must have been a one off.
