front sprocket change
Disco
I changed the rear wheel for a 2.5 inch RR and fitted a 130/90-18 Dunlop D606 and now the bike seems slow to take-off.
Has anyone fitted a 14 tooth front sprocket? Where to buy?
I'm using the 606 for off road , and the oem wheel for longer rides.
cheers, Disco
Good point, I would be interested to know if you can put a smaller sprocket on the rear to save me starting off from second as first is a great crawler gear, maybe off the older XT’s will fit?
JT Sprockets are the world's leading manufacturer of...
Check them 👍
Thanks buddy, I spent a hour or so and damned if i could find one.
cheers for your help
1 minute ago, Aleksandar13 said:
@Camel ADVADV has changed this
Have a look.
Aleks
Looks like we posted at the same time.  😎
@Disco I've deleted mine so that the thread has only one post with the same thing.
Have a look at this video 👍👀
8 minutes ago, Disco said:
@Aleksandar13Having both wheels, I want to change to 14 tooth for off road with the 130/90-18 D606. and keep the 15 tooth for on-road.
cheers, Disco
JT Quick Acceleration -1 Tooth Front Sprocket. Reducing the front...
I'm sure this is it... Just need to find one local supplier.
Aleks
17 hours ago, Disco said:
@Camel ADV, Hi Corey thanks for the fender kit.
can you help me with a 14 tooth sprocket?
cheers, Disco
Mine was a Pro-Tech off Amazon.
Been looking in both the UK and USA and the only 14 tooth sprocket I can find is US$40 plus another US$60 for postage?
Does anyone know where else I can find one?
