Foam Unifilter
Davidmarshall
Hello!
I have install the uni pre oiled foam filter on my T7.
Today, i wash it for the first time, and i want to know please, what do you do with the inner spring in this fikter to wash it, and oil it properly??!?!?
Do you remove the spring for wash/oil process?
If you remove it, how to do it without damage the foam?
Thank you!
Yes, you will need to remove the spring. The pre filter fits tightly over it. Uni filter recommend washing with any commercial foam filter cleaner or mineral turpentine, in a jar is good put the lid on and shake.  Remove,  squeezing out liquid ,use disposable gloves. Next wash out with dishwashing detergent and water. Dry, then use foam filter oil. Place in a  plastic bag, to allow it to fully wet out. It should not be dripping in oil.
