I'm confused about the USB socket/cigarette lighter slot.
Rainville
Hi all!
I finally pulled the trigger on my first bike, a brand new T7 here in Switzerland. Bike is here and is being fitted with a few accessories  but I'm confused about the USB socket(s) and I think my dealer is as well?
So, on the T7, there are 2 slots correct? One left which is already fitted with a cigarette socket I believe and one right which is empty.
I'm looking to have a double USB socket installed but my dealer seem to think the only way to do so is plug something on top of the cigarette lighter? Is that the right way?
By looking online, it seems like what I'm looking for is a complete USB slot, replacing the cigarette slot? Or am I tripping?
I'm new to all this and all the info I'm finding online is a bit complexe on this.
I don't want my dealer to just put a basic usb slot which might not work after a while if it's not a dedicated USB slot? I'm not even sure if that makes sense.
Hope you can help me clarify this :).
Thanks a ton!
Cheers.
Edited by Rainville
10 answers to this question
I'm guessing you're looking for something like this
Buy BAAS USB Vehicle Socket 2100 mA, spring-loaded cover at Louis Moto for a great price. Top brands ✓ Great selection ✓ No risk ✓ Free returns ✓
or this
Buy Albrecht twin USB socket at Louis Moto for a great price. Top brands ✓ Great selection ✓ No risk ✓ Free returns ✓
rather than a plug in charger liker this
Buy USB/Cigarette lighter plug in Adapter, 12V at Louis Moto for a great price. Top brands ✓ Great selection ✓ No risk ✓ Free returns ✓
or this
Buy USB/CIG. LIGHTER PLUG DUO-USB ADAPTER at Louis Moto for a great price. Top brands ✓ Great selection ✓ No risk ✓ Free returns ✓
I went with a second cigarette lighter style socket on the right side so I've got the choice of USB charger or plugging in the lights on my roadbook holder.
Hope this helps
Harvey
Edited by HarvC
Yes, the T7 has who slots, the left over is the standard cigarette one, the right one is empty, but there is a switched power connector behind the right panel available.
There are a few threads on the forum which explain how to add a USB port in the free socket space. This is the most recent one:
there is another thread which details exactly how to do the installation, but I can't find it quickly.
or this
or this
Hope this helps
Harvey
That's exactly what I mean.
Problem is, I'm not sure my dealer understood that. I guess I need to show them some examples.
Cheers!
These two explains about the installation of the USB Port and the removal of the front end
My only gripe with both of these threads is that they don't talk about why you shouldn't use the lines already there for a 12v socket or multiple USB ports that exceed 2 amps.
@loneranger700 i wanted a 12 volt socket that was not switched through the ignition switch and therefore would be live all the time for phone charging cradle etc and it also means that I can used it to plug in a 12 volt trickle charger to top up the bikes battery.
Do enlighten us then.
Piece of cake to thread a length of tie wire through the frame to the battery. Attach the wires to the tie wire and pull back through. Some corrugated sheathing is an advantage. Thread the wires up through the fairing and pull out through the right hand hole.
Job nearly done in 5 minutes!
Therefore, that is what I did do / I have already done that piece of cake. Cheers
Thanks @Rider 101
Anyhow, this hopefully helps others
17 hours ago, Rainville said:
Hi all!
Thanks a ton!
Cheers.
Moving this because it isn't in any way a tech tip.
