Removing OEM Centre Stand?
jeeves1275
Anyone know what the install/removal procedure is for the OEM centre stand?
Thinking of taking mine off.....
Cheers
Mark
10 answers to this question
Cheers
Mark
I will post the directions when mine arrives, been over a month waiting for it to be delivered.
i was under the bike looking at things and considering doing the same.  It looks pretty straightforward.  Springs, brackets and bolts.  Anything in particular concern you?
The spring, dealer said it was a bitch to get on....
10 hours ago, FinTen said:
Not sure if it's allowed to share directly by uploading, so I'll just link to a document picturing the installation that I randomly found on the net 😁
Nice one! That'll do it!
3 hours ago, boboneleg said:
I'm probably going to do the same as well, that bar just sticks out too much for my liking.
yeah it's that and the weight for me, plus I have a stand anyway for maintenance at home. It is convenient to have one though!
Hmmmm, looking at the instructions it looks like some bolts were replaced with longer ones, I don't have the originals.....
It's off!  Wasn't a problem in the end, have a spring puller hook  tool thing so wasn't too bad getting them off.
Had more of an issue getting the bolt out that goes in from the inside on the left hand side of the bike, but got that in the end too.
Had some replacement bolts lying around to replace the missing ones.
Job done!
Job done!
So if I didn't have "spare bolts" laying around, will I have what I need to remove the stock center-stand?  I don't want to pull it off only to find I need shorter bolts .
I think you need shorter bolts or add some kind of spacers.
Just measured....you need 2 M10x50 for the brake side and 2 M8x25 for the gear lever side
I had the M8s left over from fitting crashbars...
Edit....
If you aren't planning on selling the kit there are 2 M8x40 you could use on the gear side
Edited by jeeves1275
More info
