Tried the search function, but no luck. Sorry if this has been covered before.
I have ordered a spring for the rear shock, and am wondering how others supported the bike while replacing it. Yamaha says not to use the lower frame rails, so that leaves out using a scissors jack. Can't use a Pitbull stand on the swingarm.
I don't have a centerstand, haven't decided whether to get one yet.
Mine is sitting on a scissor jack right now with front and rear suspension removed. Not the first time and it won’t be the last.
Edited by Limey
What I use every time it get put into the garage (after every ride). Don't need a centerstand, and it rolls to move it around in the shop. Simple lever up/over center lock/lever down.
I have used in the past and will use again, an A-Frame ladder, the bike front or rear end suspended from the A-Frame (ladder frame setup standing over the bike)
I did get a used bike jack as well, not crazy about picking up the bike by the oem skid-plate.. I'm not 100% sure I trust it yet...
Tazmool
I used a trolley jack jacked against the. Sump bolt on the right hand side and put a small block of wood under the side stand. Thays how i changed my rear spring. Ive now bought a hepco centre stand.
Tazmool
which front A-frame jack did you get for the T7?
I used to use my brother's stand for his ninja, but he has since sold it...
I bought it used on Kijiji, its an old PowerFist (Princess Auto) unit.
I think any bike jack will work (anything designed for a cruiser) the Canadian Tire units, or something nicer etc.
The unit I have also came with an adapter to pick up the bike by its lower frame, have not tried that yet.
Tazmool
Have you got any more info on this item or a link to where I can get it? Looks like just the trick for my workshop...
The only link I have on this is in my garage...:classic_cool: and my computer. If you are handy with machine shop tools and have access to a CNC plasma/waterjet/laser, I can send you the files and you can build your own.
  • Community Expert
This isn't a tech tip, so im moving this out of the tech tips section.
