Open connector on right side
frogan207
I've been searching for the 2 pin on the right side of my bike for GPS connection. The aux 3 pin is obvious but the 2 pin must be buried. I do however have this connector just above the turn signal. It has no 12v when the ignition is switched on. Any ideas what it is or where the right side 2 pin is hiding on US spec bikes?20201102_084855.thumb.jpg.60699fb757622d86cce6f59c55473275.jpg20201102_084912.thumb.jpg.76ce4d13b07cd671c9d2b8799d0a28a7.jpg
There is no hidden 2 pin. You have the 12v for the extra socket on the right side and the 3 pin for the grip heaters.
2 hours ago, frogan207 said:
Correction: it has switched 12v pwr after you replace the OTHER 2 amp fuse.  Lol
I replaced that 2 amp fuse with a 5 amp, just to have some extra coverage.
It’d be nice if they supplied the other half of the connector with pins.
Can we get clear close up pics please, of all sides of the connector?
sorry, I sealed it up. If you find yourself looking for it, it is ziptied directly above the turn signal plug.
@concours. Here's a thread on the search for the elusive 2 pin male connector.
Mine was here:
  • 2 years later...
Can anyone please confirm the name of this 2 pin connector- I need the female part for a nav install- I’ve bought the wrong one already 😂
Pin up girl?
