SW motech handguards
brasscycleworks
Has anyone installed an SW Motech (Kobra' pn#HPR.00.220.24400/B) handguards? How is the fit, any modifications needed? Can stock bar end weights be used?
On 12/29/2020 at 1:00 AM, CGras said:
They are basically Barkbusters sold by SW-Motech. Fit and installation is straight forward with no mods necessary. The stock bar end weight is replaced by the parts provided in the kit.
And if you have heated grips you might want to put a washer on the throttle grip side. It was a little tight on mine and the grip didn't return properly on its own.
Thank you . I went and placed an order.
