Posted August 9, 20195 yr Hi, Is there a plug near the handlebar to connect a USB port? In the MT07 Accessories Yamaha shows a USB DC Outlet I prefer an OEM plug-in part rather than run my own wiring... Thanks for your advice, Peter
August 9, 20195 yr Author I should clarify - I do not mean the standard DC cigarette lighter socket - I mean a connector in the wiring loom.
August 9, 20195 yr ...and as far as I have seen, there are several free ends at the wiring to connect accessories. So if you have a Tenere, have a look under the front side panels. There are some explaining words said in the owner's manual...
September 9, 20195 yr QC 3.0 USB Universal Carregador de Carro À Prova D' Água Digital Display Voltímetro Com ON OFF Switch Para Carro RV ATV Moto Barco on Aliexpress.com | Alibaba Group Compre Fácil, Viva Melhor! Aliexpress.com
September 10, 20195 yr Premium Member Yes a USB unit can be fitted where 12 v cigarette lighter socket was using the power supply there. Headlight has to be removed though to fit one. The right side 12 volt cigarette socket I fitted is wired straight to the battery Edited September 10, 20195 yr by X Plane
September 25, 20195 yr On 9/10/2019 at 8:42 PM, X Plane said: Yes a USB unit can be fitted where 12 v cigarette lighter socket was using the power supply there. Headlight has to be removed though to fit one. The right side 12 volt cigarette socket I fitted is wired straight to the battery Where did you get your USB unit from? Also thanks for uploading the photos, great help! instagram.com/9to5adv
September 25, 20195 yr Premium Member 11 hours ago, JamesE said: Where did you get your USB unit from? Also thanks for uploading the photos, great help! Got USB from Amazon, eBay also sell them. No problem. Cheers. Edited September 25, 20195 yr by X Plane
October 8, 20195 yr do you know if the silver bits inside the headlamp, the ones around the LED bulbs can be accessed? I'd like to paint them black like the T7 concept
October 8, 20195 yr Premium Member 1 hour ago, ScorpionT16 said: do you know if the silver bits inside the headlamp, the ones around the LED bulbs can be accessed? I'd like to paint them black like the T7 concept Don’t know. Never looked. Imagine be sealed / be hard to open without damaging. Only guessing though.
December 21, 20195 yr Premium Member 2 hours ago, sebti said: I've done this today! Well done. Very handy mod.
July 5, 20205 yr Hello, I also want to fit a USB socket on the right side and I already prepared a wire from the battery to the side fairings on the right side, but I struggle to mount the socket itself. I saw you need to remove the complete headlight. Can you tell me what I have to remove to achieve this? Winscreen, Speedometer (2screws) and then the 4 silver screws on the backside of the headlight, but what else?
July 5, 20205 yr Premium Member 3 hours ago, ChrisXT said: Hello, I also want to fit a USB socket on the right side and I already prepared a wire from the battery to the side fairings on the right side, but I struggle to mount the socket itself. I saw you need to remove the complete headlight. Can you tell me what I have to remove to achieve this? Winscreen, Speedometer (2screws) and then the 4 silver screws on the backside of the headlight, but what else? That is it, just do it and you’ll, see here
November 1, 20222 yr On 7/5/2020 at 2:40 PM, ChrisXT said: Hello, I also want to fit a USB socket on the right side and I already prepared a wire from the battery to the side fairings on the right side, but I struggle to mount the socket itself. I saw you need to remove the complete headlight. Can you tell me what I have to remove to achieve this? Winscreen, Speedometer (2screws) and then the 4 silver screws on the backside of the headlight, but what else? I've bought a USB charger, and it actually screws into the vacant hole on th RH side, so it doesn't need the nut to hold it in place. Thus no need for taking everything apart
