T7 Tenere 700 Tail Tidy
MDB1
If I want to order T7 Tenere 700 Tail Tidy from T7Rally.com I got an option for the Indicator Mount Kit (optional 8mm/10mm). What is that? What should I choose if I want to use the Yamaha LED Plus indicators?
Edited by MDB1
8mm thread on the indicators or 10mm, it depends on what indicators you have or intend to use.
Thank you Louis. Would you happen to know if the Yamaha LED Plus indicators have 8 or 10mm thread?
I think 10mm is more "standard" - the OEM use a teardrop shape. I think you're better off with too big a hole, rather than too small.
Anyone has experience with Rally version and T7Rally tail tidy? Should I order 8mm or 10mm mount kit?
Do someone have photos to compare first version tail tidy vs the second 30 degree one?  thx
On 3/6/2021 at 11:41 AM, David Adams said:
Just installed mine. Brilliantly simple. But nice design . Thank you @T7rally.com
How do you attach the number plate to the tail?
Just drill holes and use your existing no. Plate bolts and nuts. I added a 3rd bolt at the bottom. But prob not needed
