Posted February 6, 20214 yr Acerbis T7 frame guards I'm trying to find where I can buy these, but I'm having no luck. You guys have any ideas? 🍻 Edited February 6, 20214 yr by wookee
February 6, 20214 yr Try it here. https://www.ebay.it/sch/m.html?itm=233877132247&noa=1&_ssn=fruska525&rkt=15&rk=4&pmt=0&sd=184641724056&mehot=none&pid=100675&_odkw=&algo=REC.SEED&pg=2380057&ao=1&asc=20160908105057&meid=5eb73540a19141bba421e6bc4a6ece40&item=233877132247&redirect=mobile&_osacat=0&_from=R40&_trksid=p2046732.m570.l1313&_nkw=Tenere+700+&_sacat=0
February 12, 20214 yr It was about time someone made these! Really good for not damaging the paint on the frame.
February 12, 20214 yr it's a good idea. I have only 1200 miles on mine before winter and my boots rubbed some of the pain off. Mike
February 12, 20214 yr They are also listed on T7Rally’s website @ £36.99 but on backorder. https://t7rally.com/shop/ols/products/tenere-700-t7-acerbis-frame-guards-protectors Edited February 12, 20214 yr by DT675
February 12, 20214 yr Looks like Rugged Roads carries these as well. I am starting to wish I hadn't bought dedicated master cylinder guard and frame plugs a couple of months ago, these would replace both of those as well as guard the frame a bit.https://ruggedroads.co.uk/epages/00cbb604-5d1c-407e-8207-580e14387ec5.mobile/en_GB/?ObjectPath=/Shops/00cbb604-5d1c-407e-8207-580e14387ec5/Products/24666
February 13, 20214 yr 8 hours ago, Johnnyboxer said: I bought the last few ones, delivered this afternoon - not even 24hours between order and delivery You got the “last few ones”? Ok, how much do you want for a set then? 😄
May 21, 20214 yr They have nubs in 3-4 spots on either side, and a large black rubber O-ring grabs the nubs from two points on the guards and wraps around the frame to secure them in place. They also have a couple plastic snaps in the rear set area. They come off in about 30 seconds, on in about 2 minutes. I got mine from T7 Rally along with their swing arm protector. I paired mine with the stick on frame guards underneath to prevent mud and sand from wearing the frame between the two pieces. I ride standing 80% of the time when off the highway - so mine are pretty chewed up already, but hey, that's what they're there for. I agree with burner that they are a little garish, but depending on your graphics kit and other parts, they really grew on me at least with my setup (photo is from when everything was still new).
May 21, 20214 yr 14 minutes ago, yamahabomber said: They have nubs in 3-4 spots on either side, and a large black rubber O-ring grabs the nubs from two points on the guards and wraps around the frame to secure them in place. They also have a couple plastic snaps in the rear set area. They come off in about 30 seconds, on in about 2 minutes. I got mine from T7 Rally along with their swing arm protector. I paired mine with the stick on frame guards underneath to prevent mud and sand from wearing the frame between the two pieces. I ride standing 80% of the time when off the highway - so mine are pretty chewed up already, but hey, that's what they're there for. I agree with burner that they are a little garish, but depending on your graphics kit and other parts, they really grew on me at least with my setup (photo is from when everything was still new). Thanks for the great info. If you don't mind what stick on frame guards are you using?
May 21, 20214 yr 1 hour ago, kainic said: Thanks for the great info. If you don't mind what stick on frame guards are you using? I used these ones. Really can't speak highly enough as to how well they went on - a little time with a heat gun and they seriously look like a factory part, very high quality: https://www.acdracing.com/products/frame-stickers-carbon-style-tenere-700-yamaha-t7-xtz-690-2019-2020 I also put some on the rear sets themselves, eBay/ Italian made but overpriced IMO and nowhere near the quality of the acd upper ones, but they get the job done: https://www.ebay.com/itm/Stickers-3D-Protection-Heel-Pad-Compatible-with-Yamaha-Tenere-700-2019-Yellow-/223772893571?_trksid=p2349624.m46890.l49286
April 5, 20232 yr Acerbis sucks. Horrible protection. In fact, opposite of protection. It catches mud rocks and water and rubs it with your frame. It was installed correctly. In the first picture its removed so dont judge by that picture if the installation was ok. Edited April 5, 20232 yr by Oxxa
April 5, 20232 yr On 5/17/2021 at 4:22 PM, kainic said: Anyone with a quick review on how these work? I read that they collect water/mud? They rub against your frame and damage the paint even more than without it. Check my previous reply on this thread for pictures
April 5, 20232 yr 2 hours ago, Oxxa said: Acerbis sucks. Horrible protection. In fact, opposite of protection. It catches mud rocks and water and rubs it with your frame. It was installed correctly. In the first picture its removed so dont judge by that picture if the installation was ok. You should have put helicopter tape underneath, BEFORE you attached them That's what I did and my frame is perfect underneath, after 2 years with these
April 5, 20232 yr 2 hours ago, JB700 said: You should have put helicopter tape underneath, BEFORE you attached them That's what I did and my frame is perfect underneath, after 2 years with these Can you send me a link to that helicopter tape you are using? Ill chip-paint the frame and apply the tape, and re-install the acerbis frame guard.
