MT07 Engine Guards
Southcoastbiker
MT07 engine guards fit the tenere 700. If you can live with the mt07 logo on the guards. The plastic surround on the tenere has to be cut that protects the clutch lever.
Nice idea!
I wouldn’t mind knowing a little more about your frame sliders... Bet their much lighter than my OEM engine guards.
The sliders are home made bolts welded onto angle iron all pretty strong and bolted onto 2 points. I used rubber door stops on the end of the bolts. Footpegs are from a yz they are the same width as the standard footpegs but a bit longer and have the good grips,had to grind some bits off and repaint them to fit. The engine guard on the left hand side of the bike is out enough to protect the plastic radiator tank reserve.
is it aluminum or plastic?
these might be the one I am after...didn't feel that good with anything covers up the whole entire clutch basket due to dirt/grime/heat...
