I had the front end apart to install progressive fork springs and the CamelADV high front fender kit. Upon getting everything put back together and starting up the bike, the "ABS" light is lit on the dash.
I was careful with the front wheel sensor during this work and the wheel is installed correctly with the ABS disc facing the sensor. I used a vacuum pump to bleed the brakes until the fluid ran clear of bubbles. There is resistance at the front brake lever and the bike stops well. Once it has sat a couple more days, I'll take off the reservoir cover and carefully pump out the last remaining air bubbles. But I don't think this has anything to do with the sensor.
I've had the front wheel off several times for tire swaps so what happened? I really thought I was being careful.
PackinDirt
14 answers to this question
Register a new accountSign in
