yamaha oem rear rack + outback motortek symetrical pannier rack = compatible ?
nolman
Hi,
Does anyone know if this combination is compatible ?
What pannier racks are compatible with the oem rear rack ?
Thnx!
Edited by nolman
I am also interested in this, as i have the OEM rear rack, and i would like to buy mosko panniers and they recommend outback motortek pannier rack. So i sent a mail to outback motortek and they told me its not working together. Atm i don't know if its possible to use any kind of pannier rack from the none oem ones with the oem rear one.
After outback mtek i reached mosko , and they told me that the Oil Cooled Adapter can be used with the OEM pannier racks, so the mosko panniers can be used with the oem pannier rack.
Edited by dodzylla
what i found out for now.
The givi rack is compatible if you mod it a bit. I do not know the details.
Batangacase have a fully compatible rack that is cheap with optional x-plates like the outback motortek.
I'm trying to get a quote from him.
Edited by nolman
This is the exact reply what i received from mosko:
 "Oil Cooled Adapter can be used for the OEM Yamaha pannier rack for the T700. There will be a very slight angle (between 2-3mm), as your off-set rack is 63mm, and our adapter covers 65mm."
Edited by dodzylla
So i checked today the prices, actually the mosko set in my country (Hungary) is much more expensive than the OEM aluminium one from yamaha. 😞
I'm considering getting the Batanga racks and then just cutting them down to have a slimmer profile. Also plan on getting something like huzar. Still kind of undecided yet though.
Edit: Batanga Case is being unresponsive... Soo much for that idea.
Edited by loneranger700
I have ordered the batanga racks with the x-frame tool additions.
Should be here in 2  weeks.
Will  review when i get them.
Also thinking about a huzar.
Edited by nolman
Not sure how certain this is but I've read HP Corse will be unveiling a competing exhaust to huzar next month.
  • 11 months later...
How have it ended up @nolman? Have you succeeded in combining the OEM top rack with any side panniers rack?
