K-Tech Suspension releases NEW Front Fork Cartridge Off Road Damping System (ORDS)!!!
BellissiMoto
K-Tech has heard you!  A lot of people scoffed when they came out with their piston kit for the Tenere 700 OEM forks as they wanted a cartridge kit.  Ask and you shall receive!
The K-Tech Off Road Damping System has been designed for lightweight off road motorcycles. Designed and manufactured in the UK they use the highest quality materials and processes. The system provides the rider with control and confidences in demanding off road conditions. The cartridge features a hydraulic bottoming control system which protects the rider from severe impacts when landing from large jumps. The ORDS cartridges are adjustable for compression and rebound damping.
32 clicks independent compression adjustment
32 clicks independent rebound adjustment
Hydraulic bottoming control system
Direct replacement (No machining required)
Hard chrome piston rod
Aircraft grade aluminum
Hard anodized and super finished components
Wide range of spring rates available
Like original OEM fork internals many aftermarket cartridges are manufactured with non-anodized aluminum and/or mild steel components. It is important to compare the K-Tech design and manufacturing philosophy which goes the extra mile utilizing all hard anodized aluminum or hard chromed steel internal components. This detail reduces contaminants that build up in the fork fluids which reduces maintenance, prolongs durability and increases consistency of performance. Typically, users are surprised to see clean oil emerge when performing scheduled fork maintenance rather than dark, contaminated oil.
https://www.bellissimoto.com/parts/suspension/front-suspension/cartridge-kits/K-Tech-120-019-270-015-Suspension-Off-Road-Damping-System-ORDS-Fork-Cartridges-for-the-Yamaha-Tenere-700
Best of all, is that they are on sale at 15% off!!!  DM for coupon code
  • 10 months later...
On 1/23/2022 at 7:12 AM, Masterblaster said:
has anyone tried these?
My buddy has a set, and he likes them a lot.  Of course, that's completely subjective.  He liked how they react in the stroke, and the bottom out damping characteristics on big hits.  He actually jumps his 🙂
269690218_10223074076019441_4561880084781990440_n.thumb.jpg.ce569f939bdab7b835a27aaa2854aa77.jpg
Impressive, but no crashbars?
He has SRC crash bars, but took off the top bars to save weight.  After laying it down a hand full of times, he said he's going to put them back on 🙂
