Front suspension tuning
Mark
Hi all,
apologies if this has been covered before.
-I'm 88 kg with my gear on
-Replaced back spring with Hyperpro spring.
Now, to the bouncy front end. I am not an expert off / on road :). But I hear there are a few options for improving the "spongy" front end.
What do you recommend?
thanks in advance
Mark
Hi Mark,
I replaced the stock fork springs with .66 kg/mm. Race tech gold valves in the base valves. Stayed with 10w oil to make sure I had  enough rebound. Test rode this morning. Big improvment. Felt like I could of gone a bit softer on the shim stack.
It was cold today so before I get back into them I’ll back off the compression 2 more clicks.
    If I was going to do it over again I would try K-Tech’s full kit that includes ,springs, valves, shims and rebound needles.
Or just go with Rally Raids open cartrages.
