Looking to purchase a bike lift stand to get the bike high up off the floor
any feedback or suggestions
the 3 I have been looking at are
1 Abba skylift
2 Clarke CML5
3 Easyrizer  Red
The 2nd wont lift very high
At maximum
I think I will rule that one out as I wanted it to go higher 👍
On 3/19/2021 at 1:45 AM, Stevoh said:
At maximum
Where did you hold the bike at the rear part of the stand?
Is it supporting the bike at the foot pegs brackets?
No, it's just lifting under the bash plate.
I have the same one as Stevoh and find it perfect for getting both wheels of the ground. Cheap and does the job.
The last time i looked Abba do not make a kit for the T7 so I would doubt that you could use the skylift as it looks as if it uses the bikestand as well.
Edited by Feduptryingname
I have the harbor freight lift, looks almost exactly like the Clarke one, easily lifts the bike up high enough for wheel and chain maintenance. I lock it at the second position, wheels are a few inches off the ground, it could go a little higher but that would just increase the instability since the jack base is small.  I use two straps from the crash bars to help prevent tipping.
Mike
