Indicator switch assembly
Darrenheli
Does any know how the indicator switch assembly comes off . I've removed the two screws but still won't come of seams to be joined to the or heated grips possibly
Probably glue from the grips.. šŸ‘šŸ¼Ā
One half (switch sideĀ I believe) should be held on only by the screws, and the other half (screw side) has a small pin that locates it in the handlebar so that it won't rotate. I would LIGHTLY pry the 2 halves apart once the screws are out.
Thanks for the repkys found that the dealer had put super glue on the grip and on the switch gear 😄
Edited by Darrenheli
  • Sad 1
Tenere700.net is not affiliated with YamahaĀ Motor Co and any opinions expressed on this website are solely those of ea individualĀ author and do not represent Yamaha Motor CoĀ or Tenere700.net .
