Hello everyone, current situation: rear suspension changed to a 95N / mm spring. Perfect sag of 60 mm (with maximum spring preload). Front fork not yet adjusted but has a riders sag of 70 instead of desired 63. What do you suggest: applying spacers for spring preload adjustment or changing the springs to higher spring rate (and if so which spring rate, riders weight is 102 without motorcycle gear). Suggestions are welcome.
wil59
5 answers to this question
Register a new accountSign in
