So i guess the dealer who put my Tenere together didn't read the assembly manual. I straightened out their mess-ups but my ABS wire holder isn't the right size, anyone have a picture of what the Front Fender ABS wire holder is supposed to look like?
This picture might help you? '21 Model.
Thanks, So it really just looks they have the wrong size clip on there or my speed sensor wire is missing part of the isolator.  they had the fender adjuster bolts in backwards. I had to pull the fender off tp switch them around. My buddy just purchased his and they left the front wheel spacers out.
Where did you and your buddy buy them at ? Will avoid that place like the plague
Bahahahahaha...How does someone f$&k up this bad.
The difficulty involved in installing that bolt back-asswards should have been a dead give away for the guy assembling this bike.
Wouldn’t trust those idiots to put air in a tire...
I couldn't get the bolt back out without removing the fender, so I am guessing he put it together off the bike.  I purchased mine from Lafayette Power Sports in Louisiana, they were the only dealer I could find that didn't have 5+ pre-sold bikes.
Older post, but mine was assembled in a similar manner. EVERYTHING assembled by my dealer was wrong and the left side hose clamp is non existent. I should have collected photos, as all of the windscreen plastics were assembled incorrectly also.
Oh, and here are my brake pads:
Edited by worncog
“Hey boss, this brake rotor won’t fit between the pads”
“Just hammer a cold chisel in between and pry them apart”
It’s hard to get good help these days…
You guys might want to add a review to this thread for others to benefit from as both good & bad reviews are encouraged.
