Can I reuse my grips? Pro Taper Bar Upgrade
Gsw34
I am wanting to switch to Pro Taper Evo Handlebars. Can I reuse the OEM grips?
Thanks!
Depends on how much glue your dealer used when installing them. Mine came off easily. Shoot compressed air between the grips and bars with a basketball inflating needle and see if you can twist them off.
Good luck!
I used a heat gun to help release my grips but don’t over heat them
as the rubber will melt , gently build up heat and twist off.
