Initially attempted to relocate controls on left handlebar (where the turn signal is), eventually reinstalled when I realized I can't slide it over
Removed stock hand guards
Installed SW Motech Kobra guards (barkbusters)
Installed Keso Apollo heated grips
Connected to Yamaha-provided Sumitomo 3-way connector on left side
Initially had an issue where wire was binding when turning handlebars, eventually chewed through wire. I don't know if this created a short to ground. After cutting and rewiring, Apollo grips are functioning correctly
Installed a wire pigtail to battery for my battery tender
Note this means that both battery terminals were completely disconnected from bike electronics for ~10 minutes
Upgraded rear spring on rear shock assembly
Removed rear shock assembly
Replaced stock rear shock spring with heavier duty (90 Nm) K-tech spring
Reinstalled rear shock assembly
EDIT: forgot to include that I installed Camel Adv anti-bobblehead bars
Any thoughts or tips?
Initially the ABS and CEL lights were on; I rode it a few miles and the ABS light went out, but CEL stayed on. Bike seemed to function normally during this short ride.
I have purchased a dongle to connect my OBDII scanner, but the dongle won't arrive until later in the week.
I'm of course willing to take it to the Yamaha dealer, but wanted to gather information first. It's a 1 hour trip to get there, and I'll need to borrow both a trailer and vehicle to pull that trailer, so making the trip is not trivial.
Spacejunky
I'm requesting help troubleshooting my Check Engine Light (CEL).
Forgot 1 upgrade in list
1 answer to this question
Register a new accountSign in
