Lifting your bike
Solitary1
First post on the forum.What is everyone using to lift their bikes to remove the wheels when they don't have a centre stand?
13 answers to this question
Hi Solitary1
I buyed this:
https://it.aliexpress.com/item/1005001859971201.html?spm=a2g0s.9042311.0.0.6c0c4c4dDV76g8
Used only for test, baby game for rear wheel,  not easy to use for the front wheel (with axp bash plate).
For the front I fount it easyer to use it in reverse, the circular part on the bashplate.
cheers
@Solitary1Welcome to the forum. Moved this to Tech questions as per content. Searching "Lift" brought up this thread which might help answer your question.
Thanks,I bought a used lift the same as @Hogan has,it just seems unstable on this lift plus bending down to release the hydraulic pump and hold back the safety lock whilst holding the bike with one hand isn't ideal.It's not the first bike I've lifted but certainly isn't the most intuitive to make stable.
I have one the same or very similar to the one Hogan has.
The release is a foot pedal so you don’t bend down and the safety lock can be clipped up, to be honest I’ve never engaged it. Very stable and easy pump up and drop when standing holding the bike.
Are you sure you bought the same one?
It's similar,the release is a hand operated knob that needs turning,a release peddle would be hugely beneficial.
Edited by Solitary1
Ah, sounds like a slightly different design.
The I have, in picture, is really easy to use, very stable and you can move the bike around the garage floor once up.
A bike will always wobble a bit on a stand like this, but it still takes a fair bit to knock it over.
There are tie down points too. One in the front, and two at the back in front of each castor wheel. Make sure the weight is on the safety pawl first.
Mine is also a pedal release, and the pawl has a clip to hold it back. So you can use both hands to steady the bike as it lowers.
VIVOHOME Steel Motorcycle ATV Scissor Lift Jack Crank Hoist Stand with Saddle and Safety Pins 1100 lbs
Adjust the height for precisely aligning the rear wheel, spacers, rear brake mount, and cush drive with the swingarm. so you can single handily push in the axle.
Remove the black frame lift points. Just use the red flat top to lift under the bash plate. At least put a couple layers of duct tape on top of the smooth metal lift surface or some skateboard tape, so the bike doesn't slide off.
T4vj8Wcl.jpg?1
Edited by REDHORSECA
Or just hang it from the rafters with ratchet straps.
I'm going to have to take a picture of one of my patched up/repaired garage rafters for you lol.
One other point is the engine guard, I run the SW Motech one. It has a completely flat bottom surface.
The standard guard might be more curved so will be less stable on this type of lift.
Another valid argument for lighter motorcycles!
I have the Camel Gut Guard and it helps immensely for lifting the bike on the motorcycle jack.  Without the Gut Guard, I position two pieces of wood on the jack.  One under the crankcase and one under the frame then I strap it down to the jack.  Still a bit wobbly at times and you must be careful at all times.
