So, i am doing the tubeless conversion, and one of the first things I did after removing the tire is true the rim and make sure all the spokes are tight.
after getting that done as close as possible, when i spin the tire on the balancer, the sprocket goes in and out by at least a 1/4 inch. like it is bent.
At first I thought I had the wheel mounted wrong on the balancer and un-trued it maybe, but when I look at the brake disk on the other side, it is fine. It is just the sprocket.
I havent removed it yet to see if it is the actual sprocket or the mounting plate. I hope it is just a bent sprocket.
Im not sure if I would have bent it trying to get the wheel off but I dont think I used that much pressure.
Anyway, anyone else ever see this?
Any recommendations for an after market sprocket?
Maybe different tooth count? I do mainly street riding with occasional offroad. So would there be a better count for that, without replacing the front?
jdk2man
Thanks in advance
7 answers to this question
Register a new accountSign in
