Strange alien terminated lead
Jiggier
Hi all,
When running wires for accessories I noticed this strange wire, terminated in a gel like end. Any idea what it is for? I was under the gas tank.
thanks!
Usually a ground harness splice sealed to keep the corrosion off, where your ground wires from different circuits  join back together
Why it is exposed like that? Can I terminate here ground cables from other accessories?
I wouldn't say exposed in that situation, Its under the tank and sealed with the green silicone.
As for connecting other grounds there? I wouldn't remove the coating, it's there to keep the corrosion from forming on the connection.
