prwatts
Chain Size and Sprockets
prwatts
Hi guys,   what size is the chain, and tpi of front and back sprocket. I did not find it in the manual 1f641.png😞 Thanks
The speedo over-reads about 10%.  Maybe a different sprocket ratio can fix it?
Peter
Share this post
Link to post
norcal616
It's a 525 sized chain( fairly good bet)...  vast majority of the time they read about 10% faster...this is due to regs/rules and cops know the they read a tad high and what not...I am also gonna assume it's to prevent one from using own speedo reading in court...
Healtec makes a speedo healer...
Google search says 525 size chain with 16/43 sprocket combo...
Edited by norcal616
Share this post
Link to post
TimeMachine
The chain is a 525 size as noted and the sprockets on the T7 are 15 front and 46 rear. The MT07 is 16 front and 43 rear.
I don't think changing sprockets will fix the speedo. One idea I have seen for the MT09 is to change the ABS rings that have a different "notch" count. These same parts may be identical to the MT07 and T7 as well.
Share this post
Link to post
Totti
Peter
I think that the speedometer gets its signal from the front wheel and not from the gearbox.
Share this post
Link to post
sebti
I've put a Z16 front sproket on my tenere and no problem. the spedd is calculate by ABS ring.
Share this post
Link to post
ADVUSA
What was the main motivations for the 16T ?   Driving higher speeds on the roadway?  Less too high rpm at high speeds?
Share this post
Link to post
sebti
It is to have less rpm on long distance days. Engine is as fun as with the Z15 sproket 🙂
Share this post
Link to post
tenerecanada
Good to know, thanks.
Share this post
Link to post
