Posted September 28, 20213 yr Can anyone recommend replacement front pads with more bite i am having to use more lever effort to get good braking.
September 30, 20213 yr 1 hour ago, bth2 said: i use ebc tt. check out wemoto. Anything more than "EBC TT" ? I can't find anything... about this ... Thank you, if you have code/part no. etc. And what's your feeling? It has been a real improvement in terms of "bite" ? Bruno
September 30, 20213 yr GALFER Brake Pads Yamaha 700 Tenere We upgraded the brake pads own our 700 Tenere to GALFER units, huge improvement! For the front of the bike we opted for HH Sintered compound: Better initial bite than the OEM front pads... They work great. Especially the rear.
September 30, 20213 yr EBC front standard compound non sintered = FA 181 EBC rear standard compound non sintered = FA 208
June 15, 20232 yr Bump. Looking for a middle of the road pad for fronts. Not something to eat at the disks. Ordering in U.S., responses all welcome, however ordering in the U.S.
June 15, 20232 yr I tried the EBC in the rear and they squealed until they got warm. Not for me, went back to Brembo.
June 15, 20232 yr Premium Member See video, EBC or Brembo. Big improvement especially over the oem stock rears, as they are organic and weak and wear fast. change and use gear downshifts engine braking and use the big rear brake more the bike likes rear brake use and brakes are grand. Edit: Also bleed new DOT4 brake fluid in and through.
