Translogic quick shifter, ecu re-map.
stu uk
Translogic Quickshifter and Camel mudguard kit fitted yesterday also had a direct ecu re-map done because I de-cated the bike (euro 5) work done by JHS racing in Keynsham Bristol.
So how does the bike feel after reflash? Airbox mods done?
Edited by Redbikejohn
Just fitted a translogic quickshifter to my t7. Did you have any sensor LED issues once setup. I have PWR 1, PWR 2 and RPM LED's although RPM doesn't flash when bike is turned on and idling. The sensor light only lights up when I add alot more pressure on the gear lever by which point it's already in the next gear. I feel the sensor light should illuminate earlier. Did you have an issue with this. Also did the rods that came with the system "plug and play" or did you have to cut anything to keep your gear lever in the same place and the two lines on linkage at the top lined up. I have road tested once today and the bike is up shifting without the clutch and not backing off on the throttle. Just worried that the sensor isn't doing it job if it doesn't light up on the intellishift.
