Blank plug on the right side
Redneckj
It's an accessory plug that will be used when you buy the OEM USB charger with it but if not it's free to use.
I connected my own USB and the GPS on it.
Don't know the fuse but when it melts you know which one it is and you can put in a bigger one.
@Redneckj Here's a good thread that explains locations and fuse rating for the accessory plugs.
39 minutes ago, NWrider said:
I'd be careful if you decide to install a higher amperage fuse -- the fuse is sized to protect the wiring from overheating.
The size of the cables is the same as some with a 10A fuse behind it.
If this connection has a 2 of 5A fuse you can safely up it to 10A on which most accessory's will run just fine.
Agreed if the wire size is sufficient to carry the load, although as a general rule the principle of a fuse protecting the wiring is still valid.
Thanks to everyone.  I do plan on  adding a usb with volt meter in the blank factory spot.  I’ll use that plug to power it.
